markhales85
Dec 02, 2014Aspirant
ReadyNAS Ultra 2 - No LAN, HDD or Activity lights
Good afternoon, I have a ReadyNAS Ultra 2 with 2x 2tb HDD in X-RAID which I use to store Ghost images, so it doesn't see much action. Today I have come to use it to deploy an image on a users ...
mdgm-ntgr
Dec 09, 2014NETGEAR Employee Retired
Yes the new x86_64 models can boot 4.2.x to allow you to backup your files.
Note only the x86_64 models can boot 4.2.x
The arm models: 102, 104 and 2120 cannot boot 4.2.x
SvinSimpeSWE
Sep 27, 2015Aspirant
Hi!
I'm experiencing the same thing with the exact same setup as markhales85. ReadyNAS Ultra 2 with 2x2tb HHD. I've done the factory reset boot option with a spare disk without success. I've pretty much come to terms with my loss.
I'm glad that it worked out for markhales85! Me on the other hand am currently studying and
I'm not prepared to spend that kind of money atm on a NAS solution
Is it possible to insert my disks into a ReadyNAS 102 since it's more in my price range OR do I have to spring for the more expensive models for that kind of "backward compatibility" mdgm-ntgr?
- StephenBSep 27, 2015Guru - Experienced User
Try contacting support (support.netgear.com) - they should be able to tell you what your options are (and what costs there might be).
- mdgm-ntgrSep 27, 2015NETGEAR Employee Retired
When did you purchase this Ultra 2?
Did you purchase it brand new less than 3 years ago?
- SvinSimpeSWESep 28, 2015Aspirant
StephenB Thank you for the pointer! I'll do that.
mdgm-ntgr It bought it brand new about 3 years and one week ago so my service period on the unit has sadfully ended. Now I just need some help picking a new NAS unit that will accept my disks from the old unit without erasing any data on them.
