nasmk
Mar 03, 2013Aspirant
Readynas Ultra 2 not possible to create a iSCSI target
Hi all, I m new in the iSCSI target but wanna try it for small business. When I wanna create a iSCSI target disk its not possible ... why ? i dont know... Do I need blank disks to do that? ore...
rnas_newbie
You are basically going to allocate the LUN size you need, from the space available on the unit at the time of the set-up, so it will not touch existing data elsewhere on the Ultra.
I'm assuming you've using Frontview to set it up?
If so, navigate to volumes, ISCSI tab, Enable iSCSI support
then setup how you require it,
I'm sure you will but I cannot recommend that it's tested thoroughly before committing lot's of data to the LUN etc.
