scouzer
Nov 26, 2017Aspirant
ReadyNAS Ultra 2 won't boot after power failure
Hi my Power Supply for my ReadyNAS is broken. I have now borrowed a new. But after I connected it to then boot it up properly. None of the lights to the disk are lit and I can not access the web inte...
- Nov 26, 2017
It sounds like there might have been other damage when the power brick failed. Does RAIDar find the Ultra when there are no disks installed?
If you can connect one of the disks to a windows PC (sata or via a USB adapter) you might try R-linux for Windows ( http://www.r-tt.com/free_linux_recovery/ ). It should be able to read the data volume for single-disk and RAID-1 volumes.
Nov 26, 2017Guru - Experienced User
scouzer
Raidar can't find it with the disks disconnected. I think I may give R-linux a go.
Is it easy to use, since I am not that great with Linux
- StephenBNov 26, 2017Guru - Experienced User
It's a windows program that supports the ext disk format used by your NAS, so it doesn't require any linux skills.
- scouzerNov 28, 2017Aspirant
I have now attached the disks by using a SATA to Usb converter.
But R linux doesn't seem to see the disks properly.
It just says empty disk.
Do I have to initialize it first?
- SandsharkNov 29, 2017Sensei
Don't initialize it -- that'll delete your data. What size are the drives and are you sure the converter you got supports drives of that size?
