scouzer
Nov 26, 2017Aspirant
ReadyNAS Ultra 2 won't boot after power failure
Hi my Power Supply for my ReadyNAS is broken. I have now borrowed a new. But after I connected it to then boot it up properly. None of the lights to the disk are lit and I can not access the web inte...
- Nov 26, 2017
It sounds like there might have been other damage when the power brick failed. Does RAIDar find the Ultra when there are no disks installed?
If you can connect one of the disks to a windows PC (sata or via a USB adapter) you might try R-linux for Windows ( http://www.r-tt.com/free_linux_recovery/ ). It should be able to read the data volume for single-disk and RAID-1 volumes.
Nov 26, 2017Guru - Experienced User
scouzer
Dec 04, 2017Aspirant
Another usb port Seem to do the trickđ
