MarkPearce
Mar 24, 2017Aspirant
ReadyNas104 - SMB not starting File Ownership problems.
Hi All, Hope you can help me out, I have a level of technical knowledge in as much as I think I know what has happened somehow, but need some help in determining what I need to do to fix the prob...
FramerV
Apr 02, 2017NETGEAR Employee Retired
Hi MarkPearce,
Would it be possible for you to update the firmware of the NAS first. If it is still having issues, I will be requesting for the logs and have it checked.
- MarkPearceApr 03, 2017Aspirant
Hi FramerV, Thanks for your reply.
I have already done a firmware upgrade since experiencing the problem. It is at Firmware 6.6.1 which seems to be the latest when I do a check for upgrade.
What logs would you require, let me know and I will get them for you. I have root acess.
Cheers,
Mark
- FramerVApr 03, 2017NETGEAR Employee Retired
Hi MarkPearce,
I think there is a 6.7.0 already. Please check the link that I sent.
As for the logs, if possible get all of the system logs.
Regards,- MarkPearceApr 04, 2017Aspirant
Hi,
I have upgraded to OS 6.7.0 this morning. I am still unable to start SMB.
I have gathered the logs using journalctl into a file and I can see that the problem probably started before the re-boot on the 23rd March as there are errors about files being owened incorrectly on the 22nd, but it only became an issue with starting SMB after rebooting, as the service was already running. What is the best way to get the log to you?
Cheers,
Mark
