MarkPearce
Mar 24, 2017Aspirant
ReadyNas104 - SMB not starting File Ownership problems.
Hi All, Hope you can help me out, I have a level of technical knowledge in as much as I think I know what has happened somehow, but need some help in determining what I need to do to fix the prob...
MarkPearce
Apr 03, 2017Aspirant
Hi FramerV, Thanks for your reply.
I have already done a firmware upgrade since experiencing the problem. It is at Firmware 6.6.1 which seems to be the latest when I do a check for upgrade.
What logs would you require, let me know and I will get them for you. I have root acess.
Cheers,
Mark
FramerV
Apr 03, 2017NETGEAR Employee Retired
Hi MarkPearce,
I think there is a 6.7.0 already. Please check the link that I sent.
As for the logs, if possible get all of the system logs.
