BubbaB808's avatar
May 12, 2020
ReadyNAS214 not shutting down after firmware update
I just did a firmware update to 6.10.3 for a ReadyNAS214 and now when I power it down, the display indicates do_exit+4d8 and it doesn't turn off.  My only option is to pull the power plug out, but th...
  • JohnCM_S's avatar
    JohnCM_S
    May 16, 2020
    Hi BubbaB808,
    As discussed over the private message, you may try turning On the Wake On LAN then turn it Off again if you encounter that LCD error when the NAS is shutting down.
ProSupport for Business
