aniraghome
Jul 23, 2024Tutor
readynas314 not powering on
Hi NAS experts I have a readynas 314 bought 2013-14 it has been good so far but yesterday it did not turn on meaning did not power on. It was connected to ups. Tried below did not turn on 1. I trie...
aniraghome
Jul 24, 2024Tutor
Hi Stephenb
You were spot on on amp mine is 7.5a as well.since mine was a neatgear it had it clearly labelled. While searching on YouTube for nas not powering on i found videos like this where they are replacing power supply within unit https://youtu.be/V2jqdueAn4E?si=yk7kB1k_LVXaaXIL
If the issue was with powerbrick will the green light still be on like in my picture attached? Or it could be faulty with light on?
Jul 24, 2024Guru - Experienced User
It still is possible that the power brick isn't delivering enough power to spin up the disks.
But there are other failure modes (disk failure or chassis hardware). Which is why I said it was a "risk buy".
You could see if the system boots up with the disks removed - label the disk by slot number as you take them out.
If you have a spare disk, you could also try a factory install with only that disk inserted That would be a better test, since it that works it rules out the chassis hardware. If it does work, then make sure you see if the NAS can boot with that disk in any slot.
- SandsharkJul 24, 2024Sensei
Your NAS does not have an internal power supply like many of the older models as in that video. If it is the power supply that's the issue (and the likelihood it is is high), that's a good thing -- less expensive and easier to replace.
If you do replace it, here are some pointers:
- If the vendor doesn't state the current (or wattage -- 7.5A @ 12V = 90W), and especially if they blur out or "strategically" cover the label, avoid it like the plague -- it's probably an underrated supply.
- It's best to avoid supplies listed strictly for LED lighting. They often cannot handle the inrush current of a NAS and may not be the best regulated supplies. Look for one that lists a NAS or cameras, monitors, and similar equipment.
- Be mindful that not every power supply with a 4-pin connector uses the same pin-out. The Synology NAS use the same pin-out, so you can look for that if ReadyNAS isn't listed.
If you are looking for a specific recommendation, I have used the TAIFU 4-Pin 12V 8.33A supply sold on Amazon. It has a little extra power, which can be a good thing.
While your NAS does not have an "internal power supply", it does have internal circuitry that converts the 12V to the voltages necessary to run the NAS. Those, unfortunately, are not repairable, as are pretty much everything inside the NAS. (Well, they might be repairable, but Netgear has provided no schematics to make it easy to do.) So if a replacement supply doesn't fix the issue, you are likely out of luck unless it's just a bad connector.
- aniraghomeJul 24, 2024TutorWill hope for the best that it works with the brick. Thank you again for the buying tips.
- aniraghomeJul 25, 2024TutorUpdate purchased TAIFU 4-Pin 12V 8.33A from amazon plugged it to nas it started couple of seconds it turned off again. Before i give up on nas anything i can try? I plugged on direct outlet and also on several different slots on ups. When i fully unplug both end and replug it starts i see welcome screen for 2 secs and gone.
- SandsharkJul 25, 2024Sensei
I don't know specifically about the 314, but in most ReadyNAS the welcome message is stored in the display unit, so it gets displayed if there is just 5V power (and not necessarily very well regulated 5V at that). There are a lot of things that can be wrong and cause the NAS to not boot. Starting to boot and then shutting down has fewer potential causes, but it's still pretty long. None are repairable. My best guess is that it's associated with the power-on circuit or +3.3VSB that powers it since you can't turn on via the button.
Did you see what happens without the drives?
Do you have a backup of the data? If not, then you're either going to need a replacement ReadyNAS or a data recovery method. So, knowing Netgear has exited the market, are you thinking you want to replace the NAS with a (used) ReayNAS you'll keep using for at least some time, or are you ready to move on? That can help determine the best data recovery path.
- aniraghomeJul 24, 2024TutorTried this happen to have two spares but still not powering. Will go for the new power brick. Thank you again for the tips
