gronaix
Aug 09, 2019Tutor
Readynasd not starting after creating /.force_snapshots_upgrade
Hello! On my ReadyNAS I face currently the following issue, that the readynasd service is not starting. Therefore my access to the admin page is not available. Background: within upgrading to curr...
- Aug 12, 2019
Hi,
will consider reinstalling when I have physical acces to the ReadyNAS. Currently I am trying to fix it from about 1500 km away :)
Here are the requested outputs:
Database
root@WG-LAN:~# sqlite3 --header --column /var/readynasd/db.sq3 'select * from "$timemachine_quota"' user_id enabled capacity_mb ---------- ---------- ----------- 110 1 5000 111 1 5000
Timemachine config
root@WG-LAN:~# cat /etc/netatalk/timemachine.conf # DO NOT EDIT. [MaxTv's timemachine] path = /SERIEN/.timemachine/MaxTv rwlist = MaxTv valid users = MaxTv invalid users = guest nobody @guest @nogroup vol size limit = 4768 time machine = yes [admin2's timemachine] path = /SERIEN/.timemachine/admin2 rwlist = admin2 valid users = admin2 invalid users = guest nobody @guest @nogroup vol size limit = 4768 time machine = yes
Start with debug log-level
root@WG-LAN:~# readynasd -v 5 -l - [19/08/12 21:01:48] 32056:32056 readynasd.c:1040 () readynasd log started [19/08/12 21:01:51] 32056:32056 context.c:239 (debug) NEW GLOBAL_CONTEXT: db.sq3=0xc3d118 [19/08/12 21:01:51] 32056:32056 context.c:286 (debug) NEW GLOBAL_CONTEXT: event.sq3=0xc41128 [19/08/12 21:01:51] 32056:32056 context.c:289 (debug) NEW GLOBAL_CONTEXT: globalctx=0xc3cdb8 [19/08/12 21:01:51] 32056:32056 readynasd.c:1299 () readynasd started. (restarted=0) [19/08/12 21:01:53] 32056:32056 db_access.c:127 (error) Error rndb_import() ==> rc=3 [19/08/12 21:01:53] 32056:32056 readynasd.c:1358 (error) dba import failed
As stated before, I already manually removed the btrfs subvolumes. Can this cause issues with the timemachine configuration?
I tried now to fiddle around with the timemachine.conf (haven't found this file before) and replaced it with an empty file with same access rights and the webinterface is now accessible again. For now it is fine to me, but reinstalling the device is still something to consider.
Aug 12, 2019Guru - Experienced User
It sounds like you are able to access it with ssh. Have you tried simply deleting .force_snapshots_upgrade?
You might also try an OS reinstall.
gronaix
Aug 12, 2019Tutor
Hi StephenB,
I deleted the /.force_snapshots_upgrade already, but it'll still run into the issue described above.
Will it be safe for the stored Data to reinstall the OS?
