matin
May 29, 2017Aspirant
ReadyNASPro2 data loss after freeze and reboot?
Hi all, i got a big problem with my readyNasPro2. After my return from vacation my nas totaly got freezed. After the reastart without changing the configuration it claimed "A new disk was add...
matin
Hi StephenB,
thank you.
ReclaiMe will do the job but with over 140k unsorted files this will be a lot of work afterwards (just running the demo version).
Are there any similar OSX file recovery apps?
I will try to get in touch with the Netgear support. Maybe they got an idea of restoring the files including the file structure.
regards,
Martin
May 29, 2017Guru - Experienced User
Yes. Once you get the NAS running again, you should put a backup plan in place, to avoid the need for recovery in the future. But the issue at hand is to get the data recovered.
I don't have an OSX systems, so I have no recommendation there. Most of these tools seem to be either linux or Windows based.
- Jan 17, 2024Retired_Member
