loky5
Feb 21, 2016Aspirant
Readynass RN104 - hot swap problem #26498818
Hello from France
I have a readynas 104 with 4 HDD (3x3To + 1x1To ~6.3To only one Volume with X-Raid)
I bought a new 3To HDD to replace the 1To. I did an hotswap, but wrong disk, so I let it ...
lundmilo
Feb 21, 2016Luminary
I think that if you first pulled the wrong disc and then try to use it in another bay, you have to format it beforehand, so 's the NAS sees it as a previously used disc.
- StephenBFeb 21, 2016Guru - Experienced User
lundmilo wrote:
I think that if you first pulled the wrong disc and then try to use it in another bay, you have to format it beforehand, so 's the NAS sees it as a previously used disc.If he doesn't have a backup he should contact support. In the screen shot, none of the volumes are functioning (including the original xraid volume).
- loky5Feb 21, 2016Aspirant
Thank you for the replies.
I have opened a ticket for support.
But I tried lundmilo's idea :
I pulled out the disk 4, replaced it with the new 3To nothing happened, for sure.
I waited a couple of hour, and I replaced it with the disk 4. And now it resyncing. I don't understand why or what...
If it resyncs, it must know a RAID is lying down there
- cpu8088Feb 22, 2016Virtuoso
just destroy the data-0 and data-1
it should rebuild under x-raid
