fiber2
Jun 08, 2017Tutor
Rebuild at disk swap
Hi, I will swap one of the tree HDDs because of SMART error warnings. I think after removing the problematic HDD the NAS will immedeatily start a job (I guess will will redistribute to be redund...
- Jun 08, 2017
fiber2 wrote:
Is it better to power down the NAS or to do a hot swap anyway? I can easily power down the NAS to do the swap.
I always recommend a hot swap, though a cold swap also works.
fiber2 wrote:
To prevent access, while completing the rebuild, can I take out the ethernet connection. That would be much easier than making sure nobody is trying to read or write from/to the NAS with any of the multiple devices.
You can, but I don't see a reason to. The NAS can be used during the resync (though performance will be less). That's the main benefit of RAID - keeping data available.
Jun 08, 2017Guru - Experienced User
