jackerhack
Jan 20, 2014Aspirant
Recovering from apt-get dist-upgrade
Hey all, my first time here. I've been a happy ReadyNAS user for close to a year. I have a Duo v2 at home and an NV+ v2 at work, all loaded with 3 TB drives. Last week I was trying to setup my s...
mdgm-ntgr
Jan 21, 2014NETGEAR Employee Retired
There should be three partitions on the disks. OS Partition, Swap and Data Volume
Need to use mdadm and lvm2 when trying to mount it. However it looks like the data volumes might be missing.
See if support can help.
If you want to run the latest Debian on it take a look at the natisbad links in my post above. The author of that site has done a lot of work to make that possible.
