HadesCA
Sep 12, 2022Aspirant
Recovering X-Raid2 files using Linux/Ubuntu
I have two ReadyNAS Pro Pioneer 6-bay NAS boxes. I thought buying two would add safety so if one failed the other could be used to recover files. Wrong. Both failed at the exact same time. First ...
mdgm
Sep 18, 2022Virtuoso
All ARM and x86 ReadyNAS use mdadm for the RAID.
RAIDiator-x86 4.2.x and RAIDiator-arm 5.3.x use lvm2 for the data volume(s) and mdadm for the RAID.
So assembling the RAID using mdadm was necessary before using vgscan etc. as you suggest.
However it’s recommended to check disk health and the state of the RAID first rather than simply hoping it is fine and blindly assembling it.
HadesCA
Sep 20, 2022Aspirant
Actually right now I'm doing this all with test drives just to prove out the process that I "can" load it up and rescue the data this way before I try to recover from my real data disks. But I have little to no linux experience so I was really hoping someone here would have enough experience to let me know what commands to use and how to use them.
That said regarding your comment: "check disk health and the state of the RAID first" - how do I do that? Are those also LVM2/mdadm commands as well?
When I run the assemble I can see the additional disk volume and at its root are what look like shortcuts to the SHARE names I used when I created the shares on ReadyNAS. But the links are broken. It says:
"The link "Bluray" is broken"
This link cannot be used because its target "/c/Bluray/" doesn't exist.
The exact details are in the attached image.
I'm hoping someone can guide me to how to mount it correctly so "/c/Bluray/" works. Hopefully more specific than "use the mount command".
