icosmos72
Sep 14, 2012Aspirant
Recovery after power supply failure
Hello forum --- I had a ReadyNAS RND4000 which experienced "the power supply problem". It had two 2TB drives, so 2TB of dual-redundant storage total. Netgear tech support promptly got me a new chas...
mdgm-ntgr
Sep 14, 2012NETGEAR Employee Retired
Then you have a NV+ v1 hardware revision 3: How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
Have you tried an OS Re-install?: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
