medimus
Mar 02, 2010Aspirant
Recycle bin fills up my ReadyNAS
I use Radiator 1.4.6 with my ReadyNAS Duo. About two months ago I enabled the Recycle bin for my CIFS share "Backup", with options "Remove files older than: 10 days" and "Limit Recycle Bin to: 200 Mb" about 2 months ago. Yesterday I noticed that of my 1 Tb discs 600 Gb were used, and found that most of this was the Recycle bin, with loads of copies of backup files through NTI Shadow for ReadyNAS. It is configured to make a backup once a day with 3 older copies saved, so the fourth copy sends the former one to Recycle bin I suppose. Now I've spent several hours erasing this huge bin (that is from now on disabled).
Does anyone recognize this problem - that the Recycle bin doesn't empty itself as it should according to the options? I have turned it off now, and realize that three version copies in the backup usually are enough.
- JMehringApprentice
ewok wrote: Can you run stat on one of these files in the recycle bin and post the result?
Sure...
-rwxrwxr-x 1 admin admin 418736128 2011-07-10 01:04 1x64b-Final.avi
-rwxrwxr-x 1 admin admin 733034496 2011-07-10 01:05 1x65b-Daily.avi
-rwxrwxr-x 1 admin admin 246784 2011-11-16 22:16 Thumbs.db
Energy-Storage:/c/media/Recycle Bin/Season 01# stat 1x65b-Daily.avi
File: `1x65b-Daily.avi'
Size: 733034496 Blocks: 1431720 IO Block: 4096 regular file
Device: fd00h/64768d Inode: 12747480 Links: 1
Access: (0775/-rwxrwxr-x) Uid: ( 98/ admin) Gid: ( 98/ admin)
Access: 2011-07-10 01:05:42.618696000 -0400
Modify: 2011-07-10 01:05:52.168898000 -0400
Change: 2011-11-18 22:27:58.830775481 -0500
Energy-Storage:/c/media/Recycle Bin/Season 01# date
Sun Nov 20 15:24:34 EST 2011
Energy-Storage:/c/media/Recycle Bin/Season 01# find '/c/media/Recycle Bin' -type f -ctime +1
Energy-Storage:/c/media/Recycle Bin/Season 01# - ewokNETGEAR ExpertThat's strange, here are my results:
nas-AA-22-B5:/c/media/Recycle Bin# stat abc
File: `abc'
Size: 0 Blocks: 0 IO Block: 4096 regular empty file
Device: fd00h/64768d Inode: 13369354 Links: 1
Access: (0644/-rw-r--r--) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2011-11-11 00:00:03.606645267 -0800
Modify: 2011-11-11 00:00:03.606645267 -0800
Change: 2011-11-11 00:00:03.606645267 -0800
nas-AA-22-B5:/c/media/Recycle Bin# find '/c/media/Recycle Bin' -type f -ctime +1
/c/media/Recycle Bin/abc
nas-AA-22-B5:/c/media/Recycle Bin# date
Tue Nov 29 16:04:09 PST 2011
nas-AA-22-B5:/c/media/Recycle Bin# find --version
GNU find version 4.2.28
Features enabled: D_TYPE O_NOFOLLOW(enabled) LEAF_OPTIMISATION
What do you get when you run "find --version"?
