weggelmc
Dec 28, 2010Aspirant
Recycle Bin not working
I have enabled the recycle bin on my shares, and the folder shows up in the file list. However, when I delete a test file from a folder in the same share, it does not go into the recycle bin - the bi...
andrewC1
May 20, 2011Aspirant
Hi All,
Not sure if this is related to same problem you have. I noticed that when I created folders and then deleted them they did not go into Recycle Bin (which I setup previously).
I then noticed that if the folder I deleted was empty, nothing appeared in the recycle bin. It only appears when there are files in the folder. So check you are deleting a folder containing files when testing. Dont know why this happens.
Andrew.
Andrew.
