weggelmc
Dec 28, 2010Aspirant
Recycle Bin not working
I have enabled the recycle bin on my shares, and the folder shows up in the file list. However, when I delete a test file from a folder in the same share, it does not go into the recycle bin - the bi...
ewok
May 23, 2011NETGEAR Expert
Which version of the firmware are you using? Over which protocol are you doing the deletion (CIFS, FTP, HTTP)?
