weggelmc
Dec 28, 2010Aspirant
Recycle Bin not working
I have enabled the recycle bin on my shares, and the folder shows up in the file list. However, when I delete a test file from a folder in the same share, it does not go into the recycle bin - the bi...
mipy
Sep 26, 2011Aspirant
Firmware: RAIDiator 4.2.19
Protocl : CIFS
Hi All,
I have the same problem: activated 'Enable Recycle Bin' in CIFS for 3 shares, and it works only for 2 !
I tried to disabled and enabled it many times for my third share, I also tried to change size or delay, no changes, the files that I delete in this share do not go to the recycle bin.
For the two others shares, I just enabled Recycle Bin and it worked immediately.
What can I try ?
Mipy
Protocl : CIFS
Hi All,
What can I try ?
Mipy
