weggelmc
Dec 28, 2010Aspirant
Recycle Bin not working
I have enabled the recycle bin on my shares, and the folder shows up in the file list. However, when I delete a test file from a folder in the same share, it does not go into the recycle bin - the bi...
kevsterrrrr
Jan 11, 2012Aspirant
Hi,
I too am having the same issue with the same config, Raidiator 4.2.19, CIFS share.
this used to work initially but now has broken for some reason, shame as it was a good failsafe.
I just disabled the recycle bin, deleted the folder and re-enabled, still no go.
Can't reboot the nas at the moment, will try the disable recycler, delete folder and reboot step later on when no one is on the nas.
Anyone get to the bottom of this?
Thanks,
Thanks,
