weggelmc
Dec 28, 2010Aspirant
Recycle Bin not working
I have enabled the recycle bin on my shares, and the folder shows up in the file list. However, when I delete a test file from a folder in the same share, it does not go into the recycle bin - the bi...
kevsterrrrr
Jan 21, 2012Aspirant
Hi All,
been away for a bit, this is now working after a disable, delete of the recycle folder, and a reboot then re-enable.. seems to be behaving now so thats good thanks for all your assitance :)
