mediasurfer
Feb 06, 2021Tutor
Reformatting former RAID HDD for repurposing.
I had a near disaster with my ReadyNas 516 6 x 4TB. I had a single HDD failure and promply ordred a 4TB replacement. Unfortunately i missed the next day delivery and had to go away to my work for thr...
- Feb 06, 2021
I will have a newer caddy delivered today. Hopefully that will be it.
Feb 06, 2021Guru - Experienced User
mediasurfer wrote:
I removed these to create a single parftion using disk manager, but it only reconises less than half of the 4 TB. I have tried using diskpart and clean to no avail. I am now wondering if my caddy is too old for a 4TB HDD
There are old USB docks/adapters that only support 2 TB, and it sounds like you might be using one.
- mediasurferFeb 06, 2021Tutor
- mediasurferFeb 07, 2021Tutor
I received a new USB 3.0 to SATA Hard Drive Docking Station today and as expected this solved the issue
