BernyB
Apr 29, 2020Tutor
Remote RN104 btrfs corrupted (empty volumes)
Hi, I was running a RN316 (v6.5.1) smoothly at work and Replicate to a remote RN104 (6.5.2). I know I did not update the firmware but those versions were the most stable for me and it's hard to keep...
Sandshark
Apr 30, 2020Sensei
That's a big jump in OS version. You definately need to update. But you might want to only go as far as the latest "long term support" version (6.9.6) initially, especially on the 104, which has less memory. Once you cross a major revision line (second decimal), there is no going back.
