UnknownAXHF
Sep 19, 2018Aspirant
Remove inactive volumes - RN314
Hi,
So I updated to Firmware 6.9.4 the other night, I turned the nas off yesterday afternoon and restarted it this morning to be greeted with "Remove inactive volumes to use the disk. Disk #1,2...
- Sep 19, 2018
Hi Marc,
Thanks for that, I hadn't replaced any disk taken anything out for that matter.
So it's possibly down to a drive failure? If so, do I have to have replacement disks ready? (I have none atm) The drive is still under warranty though, it also says it's healthy on raidar
Are the drives bundled with the NAS? or they still have warranty with the Manufacturer? I would advised claiming warranty from the Manufacturer or NETGEAR if this is the case.
You will have to ready your replacement once this is handled by L3 experts, The lost of volume data is from the drive failure and not the upgrade itself.
RAIDar might be showing healthy disks but what needs to be done is to have your RAID mounted so you can access Data. I do think that only Disk on Ch4 is the only one needing replacement.
Hope this helps!
Regards
UnknownAXHF
I have also just seen there are a few topics all posted today with same reported issue? Firmware issue?
https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-2120-remove-inactive-volumes/td-p/1636222/jump-to/first-unread-message - 2018-09-18 10:37 PM https://community.netgear.com/t5/Using-your-ReadyNAS/Lost-all-disks-after-firmware-6-9-4-upgrade/td-p/1640701/jump-to/first-unread-message - 2018-09-18 09:14 PM https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-316-Volume-gone-Remove-inactive-volumes-to-use-disk/td-p/1638434/jump-to/first-unread-message - 2018-09-18 05:20 PM https://community.netgear.com/t5/Using-your-ReadyNAS/Urgent-Help-Needed-ReadyNas-214-gives-a-No-Volume-Exists-error/td-p/1640652/jump-to/first-unread-message - 2018-09-18 01:39 PM
Marc_V
Sep 19, 2018NETGEAR Employee Retired
Hi UnknownAXHF
Welcome to the Community!
Base on the logs you posted, your disks failed after the update. Were you having warnings before the update regarding your disks status? Losing the volume might be of multiple disk failure or another issue.
You may want to check if you can still download the full logs and see disk_info, volume, kernel and systemd-journal
You can PM me the contents if possible.
Regards
- UnknownAXHFSep 19, 2018Aspirant
Hi Marc,
I updated Sunday or Saturday night I believe, I had no warnings or alerts from what I could see logging into the NAS throughout Monday.
I've sent you a PM with a link to the log file.
Thanks
Tom
