swsb22
Apr 04, 2018Aspirant
Remove Time Machine and all backups
Hi I have a ReadyNAS Duo [X-RAID], which someone set up for me some years ago. At the time they set it as a backup for Time Machine, however my Mac hard drive had to be replaced and I was unable to ...
Marc_V
Apr 04, 2018NETGEAR Employee Retired
Hi swsb22
you can actually remove the sparse image/bundle throughfew procedures. You can check it here.
Hope this helps!
Regards
- swsb22Apr 04, 2018Aspirant
Hi Marc_V
I tried once before to remove the sparsebundle by deleting it when logged in as admin via AFP and first time got the spinning wheel of death and then the next time it seemed to take ages to do nothing, so I stopped it. I've no idea how to use SSH.
If I just delete the backup in frontview, then disable TM in frontview, would that not get rid of the sparsebundle and give me space back?
Regards
swsb22
- Marc_VApr 04, 2018NETGEAR Employee Retired
You can disable Time Machine on ReadyNAS and locate the sparsebundle and delete it.
Each Mac client using Time Machine can delete the sparsebundle image used by that client by going into the ReadyNAS share on the ReadyNAS device.
It should give the space taken back as free space but logging in through AFP using ReadyNAS as user should be quicker you can find the sparsebundle under /c/.timemachine.
To disable TM you can just uncheck the box. You can use this as reference Easy Time machine setup.
Regards
- Marc_VApr 08, 2018NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
