Weaverita
Oct 10, 2020Apprentice
Removing a disk from XRAID
I am currently using 4 6TB drives in an X-RAID configuration. I would like to upgrade to 3 new drives using 12TB drives in X-RAID. In other words fewer larger disks. I know that I can selectively...
Oct 10, 2020Guru - Experienced User
Weaverita wrote:
The challange, how do tell X-RAID to rebuild without using the fourth drive as there is plenty of space on drives 1, 2 and 3?
You can't. There is a way to shrink the volume with ssh, but there is some risk. It's simplest just to leave the last 6 TB drive in place.
- WeaveritaOct 11, 2020Apprentice
Thanks StevenB. Your fast response is greatly appreceated. That said, this seems like a somewhat straigforward maintenance opportunity for ReadyNAS systems to keep them current. Sometimes, adminstrators like to vacate old disk(s) just because they have a bunch of hours on them. :-) Is it not not an administrator's role to be parinoid about failures? Retorical question... Thank you again sir!
- StephenBOct 11, 2020Guru - Experienced User
Shrinking a volume is tricky, so it's not that surprising that Netgear hasn't chosen to automate it.
Here's a post from Sandshark going over the steps: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Reducing-RAID-size-removing-drives-WITHOUT-DATA-LOSS-is-possible/td-p/1736125
