rykr
Apr 30, 2016Aspirant
__VERY__long rebuild time. Can I pull the drive?
I recently got a RN204. I installed a single 2TB drive and filled it to 95% full with data. Then I added a second drive. It proceeded to resync. That took 28 hours after which it indicated the vo...
Apr 30, 2016Guru - Experienced User
rykr wrote:
I've shelled into the nas. ps aux shows /usr/sbin/readynasd taking only 1.0% cpu and 2.2% mem. I know there are lots of sector problems on drive #3. At 1.7% done rebuilding, what are chances that pulling the third drive (the one I last put in) destroys the entire array?
If the drive is failing, then that could explain the slow rebuild time (and your data is at risk, unless you are using dual-redundancy raid). Are you seeing more reallocated sectors being logged as the resync proceeds?
mdgm-ntgr
May 02, 2016NETGEAR Employee Retired
As I believe has been mentioned by Skywalker elsewhere there is a known issue with hot-swap on the 200 series and 210 series that is addressed in ReadyNASOS 6.5.0 (RC2). You may wish to try that.
