dldb
Mar 09, 2023Aspirant
removing thumbs db
tried lots of things no result. untill now. easy, rename thumbs.db to thumbs.txt. delete and done
- Mar 10, 2023
dldb wrote:
thx, but this is not for me as a user not an expert.SSH is likely not for you.
But the method here should be something you can handle:
dldb
Mar 10, 2023Aspirant
what is ssh? And how can i use it?
Mar 10, 2023Guru - Experienced User
It's a way to access the linux command line interface in your ReadyNAS
As far as removing thumbs.db files goes, the best option is to tell Windows not to create them in the first place.
- dldbMar 10, 2023Aspirantthx, but this is not for me as a user not an expert.
