bjt23
Aug 15, 2019Aspirant
Replaced drive, but second drive failed during resync (NV+ v2)
Hi all, managed to get myself into a bad situation. I have a ReadyNAS NV+ v2, with four 2TB drives in it. I decided to purchase four new 4TB drives to increase my storage space. I pulled out old d...
Sandshark
Aug 23, 2019Sensei - Experienced User
If you want the best chance of recoverying data, you should stop tinkering and contact Netgear support for paid recovery.
I don't have a lot of exp[erience messing around under the hood on OS5.x. On other OS's, a volume created external to the GUI will be recognized by the GUI if the proper entry is in /etc/fstab. So, if the recreation works at all, I would think that getting the GUI to recognize it should not be too difficult. The underlined text being the key, of course.
