Raaahbin
Sep 15, 2015Aspirant
Replaced failing disk in NV+ v2 - both volume expansion and volume scan fail
Hi folks, I'm getting some slightly peculiar behaviour from my NV+ v2, and would really appreciate some help in troubleshooting. A week or so ago, I started getting errors on disk 1 of my NAS...
Raaahbin
I couldn't include log output in the original message due to character limits.
I have downloaded the logs, and happy to look things up in specific places. In the mean time, the following seem to be the relevant part of expand_md.log:
[2015/09/14 14:39:47 23206] Added drive to md, grown=1/0xbebb6a6c [2015/09/14 14:39:47 23206] Repair caused array grow, will do expansion... [2015/09/14 14:39:56 23206] LINE 4440: exec command: vgdisplay -c c > /var/log/frontview/.V_E.vgdisplayout ; lvdisplay -c c > /var/log/frontview/.V_E.lvdisplayout File descriptor 3 (/etc/resolv.conf (deleted)) leaked on vgdisplay invocation. Parent PID 29226: sh File descriptor 3 (/etc/resolv.conf (deleted)) leaked on lvdisplay invocation. Parent PID 29226: sh [2015/09/14 14:39:56 23206] 0 vg= c lv= /dev/c/c [2015/09/14 14:39:56 23206] 1 vg=r/w lv=c [2015/09/14 14:39:56 23206] 2 vg=772 lv=3 [2015/09/14 14:39:56 23206] 3 vg=-1 lv=1 [2015/09/14 14:39:56 23206] 4 vg=0 lv=-1 [2015/09/14 14:39:56 23206] 5 vg=1 lv=1 [2015/09/14 14:39:56 23206] 6 vg=1 lv=19485687808 [2015/09/14 14:39:56 23206] 7 vg=-1 lv=148664 [2015/09/14 14:39:56 23206] 8 vg=0 lv=-1 [2015/09/14 14:39:56 23206] 9 vg=2 lv=0 [2015/09/14 14:39:56 23206] 10 vg=2 lv=-1 [2015/09/14 14:39:56 23206] 11 vg=9753329664 lv=253 [2015/09/14 14:39:56 23206] 12 vg=65536 lv=0 [2015/09/14 14:39:56 23206] 13 vg=148824 lv=13 [2015/09/14 14:39:56 23206] 14 vg=148664 lv=14 [2015/09/14 14:39:56 23206] 15 vg=160 lv=15 [2015/09/14 14:39:56 23206] 16 vg=rGs2iy-Av5h-nfXC-oAH1-bzUt-W3OP-Vfcp37 lv=16 [2015/09/14 14:39:56 23206] 17 vg=17 lv=17 [2015/09/14 14:39:56 23206] 18 vg=18 lv=18 [2015/09/14 14:39:56 23206] 19 vg=19 lv=19 [2015/09/14 14:39:56 23206] LINE 4879: exec command: pvresize /dev/md2 File descriptor 3 (/etc/resolv.conf (deleted)) leaked on pvresize invocation. Parent PID 23206: /usr/sbin/expand_md Physical volume "/dev/md2" changed 1 physical volume(s) resized / 0 physical volume(s) not resized [2015/09/14 14:39:57 23206] LINE 4879: exec command: pvresize /dev/md3 File descriptor 3 (/etc/resolv.conf (deleted)) leaked on pvresize invocation. Parent PID 23206: /usr/sbin/expand_md Physical volume "/dev/md3" changed 1 physical volume(s) resized / 0 physical volume(s) not resized [2015/09/14 14:39:59 23206] LINE 4440: exec command: vgdisplay -c c > /var/log/frontview/.V_E.vgdisplayout ; lvdisplay -c c > /var/log/frontview/.V_E.lvdisplayout File descriptor 3 (/etc/resolv.conf (deleted)) leaked on vgdisplay invocation. Parent PID 29236: sh File descriptor 3 (/etc/resolv.conf (deleted)) leaked on lvdisplay invocation. Parent PID 29236: sh [2015/09/14 14:40:00 23206] 0 vg= c lv= /dev/c/c [2015/09/14 14:40:00 23206] 1 vg=r/w lv=c [2015/09/14 14:40:00 23206] 2 vg=772 lv=3 [2015/09/14 14:40:00 23206] 3 vg=-1 lv=1 [2015/09/14 14:40:00 23206] 4 vg=0 lv=-1 [2015/09/14 14:40:00 23206] 5 vg=1 lv=1 [2015/09/14 14:40:00 23206] 6 vg=1 lv=19485687808 [2015/09/14 14:40:00 23206] 7 vg=-1 lv=148664 [2015/09/14 14:40:00 23206] 8 vg=0 lv=-1 [2015/09/14 14:40:00 23206] 9 vg=2 lv=0 [2015/09/14 14:40:00 23206] 10 vg=2 lv=-1 [2015/09/14 14:40:00 23206] 11 vg=10730078208 lv=253 [2015/09/14 14:40:00 23206] 12 vg=65536 lv=0 [2015/09/14 14:40:00 23206] 13 vg=163728 lv=13 [2015/09/14 14:40:00 23206] 14 vg=148664 lv=14 [2015/09/14 14:40:00 23206] 15 vg=15064 lv=15 [2015/09/14 14:40:00 23206] 16 vg=rGs2iy-Av5h-nfXC-oAH1-bzUt-W3OP-Vfcp37 lv=16 [2015/09/14 14:40:00 23206] 17 vg=17 lv=17 [2015/09/14 14:40:00 23206] 18 vg=18 lv=18 [2015/09/14 14:40:00 23206] 19 vg=19 lv=19 [2015/09/14 14:40:00 23206] Facts:vg_total=163728,vg_alloc=148664,vg_free=15064,lv_new=14904,lv_total=% [2015/09/14 14:40:00 23206] LINE 4694: exec command: lvextend /dev/c/c -l +14904 File descriptor 3 (/etc/resolv.conf (deleted)) leaked on lvextend invocation. Parent PID 23206: /usr/sbin/expand_md Extending logical volume c to 9.98 TiB Logical volume c successfully resized [2015/09/14 14:40:02 23206] LINE 4892: exec command: /frontview/bin/volumescan & [2015/09/14 14:40:03 23206] LINE 540: exec command: echo "DOING_F_RESIZE" > /.os_V_E_continue [2015/09/14 14:40:03 23206] LINE 4569: exec command: resize2fs -pf /dev/c/c resize2fs 1.41.14 (22-Dec-2010) File descriptor 3 (/etc/resolv.conf (deleted)) leaked on vgscan invocation. Parent PID 29287: sh File descriptor 3 (/etc/resolv.conf (deleted)) leaked on lvdisplay invocation. Parent PID 29244: sh File descriptor 3 (/etc/resolv.conf (deleted)) leaked on pvdisplay invocation. Parent PID 29244: sh File descriptor 3 (/etc/resolv.conf (deleted)) leaked on pvdisplay invocation. Parent PID 29244: sh resize2fs: Memory allocation failed while trying to resize /dev/c/c Please run 'e2fsck -fy /dev/c/c' to fix the filesystem after the aborted resize operation. Filesystem at /dev/c/c is mounted on /c; on-line resizing required old desc_blocks = 581, new_desc_blocks = 639 [2015/09/14 14:56:54 23206] Expand second phase error 10: resize2fs, err=0x100 [2015/09/14 14:57:04 23206] Volume expand failed, no drive added [2015/09/14 14:57:04 23206] launch expand_md again for vol expansion [2015/09/14 14:57:04 23206] LINE 6815: exec command: /usr/sbin/expand_md >> /var/log/frontview/expand_md.log 2>&1 & [2015/09/14 14:57:05 23206] xraid mode 1 disk count 4 flex level -1 [2015/09/14 14:57:05 23206] raid mode 1 data_degraded 1 disk count 4 [2015/09/14 14:57:05 23206] LINE 5210: exec command: /usr/sbin/expand_md -a super >> /var/log/frontview/expand_md.log 2>&1 & [2015/09/14 14:57:05 23206] LINE 5213: exec command: /frontview/bin/volumescan & [2015/09/14 14:57:06 23206] STAGE_WIPE: Clean my_pid 23206 [2015/09/14 14:57:06 29496] STAGE_CHECK: saved my_pid 29496 in check mode. [2015/09/14 14:57:06 29496] RAID MODE: 1, sn= File descriptor 3 (/etc/resolv.conf (deleted)) leaked on lvs invocation. Parent PID 29508: sh [2015/09/14 14:57:06 29496] LINE 4928: exec command: lvs > /var/log/frontview/.V_E.snapshotstat [2015/09/14 14:57:07 29496] Current file system status: ext4 [2015/09/14 14:57:07 29496] LINE 6523: exec command: rm -fr /var/log/frontview/.V_E.* [2015/09/14 14:57:07 29496] X_level: 5 [2015/09/14 14:57:07 29496] /usr/sbin/expand_md -a super [2015/09/14 14:57:07 29496] MD degraded 0, bg_job 0, boot 0 [2015/09/14 14:57:07 29496] ++++Write 2049488 byte to configuration++++ [2015/09/14 14:57:07 29496] /var/log/frontview/.known_cfgdir/W1F2NA5K [2015/09/14 14:57:07 29496] gpt sig:0,mbr sig:0,fake type:0 [2015/09/14 14:57:07 29496] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2 [2015/09/14 14:57:07 29496] LINE 9650: exec command: sgdisk -p /dev/sdc | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/W1F2NA5K [2015/09/14 14:57:10 29496] /var/log/frontview/.known_cfgdir/S301BHFT - [2015/09/14 14:57:16 29496] used_disk_pt_count:4,start:4 xraid level is 5 [2015/09/14 14:57:16 29496] Not enough disk for a new array, drives with free space: 0, X_level:5 [2015/09/14 14:57:16 29496] STAGE_WIPE: Clean my_pid 29496 [2015/09/14 14:57:45 29078] STAGE_CHECK: saved my_pid 29078 in check mode. [2015/09/14 14:57:45 29078] RAID MODE: 1, sn= [2015/09/14 14:57:45 29078] LINE 4928: exec command: lvs > /var/log/frontview/.V_E.snapshotstat [2015/09/14 14:57:45 29078] Current file system status: ext4 [2015/09/14 14:57:45 29078] LINE 6523: exec command: rm -fr /var/log/frontview/.V_E.* [2015/09/14 14:57:46 29078] X_level: 5 [2015/09/14 14:57:46 29078] /usr/sbin/expand_md -a super [2015/09/14 14:57:46 29078] MD degraded 0, bg_job 0, boot 0 [2015/09/14 14:57:46 29078] ++++Write 2049488 byte to configuration++++ [2015/09/14 14:57:46 29078] /var/log/frontview/.known_cfgdir/W1F2NA5K [2015/09/14 14:57:46 29078] gpt sig:0,mbr sig:0,fake type:0 [2015/09/14 14:57:46 29078] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2 [2015/09/14 14:57:46 29078] LINE 9650: exec command: sgdisk -p /dev/sdc | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/W1F2NA5K [2015/09/14 14:57:47 29078] Sgdisk /dev/sdc partition to file Error. rc = -1 [2015/09/14 14:57:47 29078] /var/log/frontview/.known_cfgdir/S301BHFT - repetitions snipped for character limits -
[2015/09/14 14:57:51 29078] gpt sig:0,mbr sig:0,fake type:0 [2015/09/14 14:57:51 29078] get disk /dev/sda format is (GPT=2,MBR=1,MX=3,MISC=-1): 2 [2015/09/14 14:57:51 29078] /dev/sda used/total/partitioned = 3907016483/3907018584/3907016483, 60000000 [2015/09/14 14:57:51 29078] used_disk_pt_count:4,start:4 xraid level is 5 [2015/09/14 14:57:51 29078] Not enough disk for a new array, drives with free space: 0, X_level:5 [2015/09/14 14:57:51 29078] STAGE_WIPE: Clean my_pid 29078 [2015/09/14 14:58:07 29493] STAGE_CHECK: saved my_pid 29493 in check mode. [2015/09/14 14:58:07 29493] RAID MODE: 1, sn= File descriptor 3 (/etc/resolv.conf (deleted)) leaked on lvs invocation. Parent PID 29652: sh [2015/09/14 14:58:07 29493] LINE 4928: exec command: lvs > /var/log/frontview/.V_E.snapshotstat [2015/09/14 14:58:08 29493] Current file system status: ext4 [2015/09/14 14:58:08 29493] LINE 6523: exec command: rm -fr /var/log/frontview/.V_E.* [2015/09/14 14:58:08 29493] X_level: 5 [2015/09/14 14:58:08 29493] /usr/sbin/expand_md [2015/09/14 14:58:08 29493] MD degraded 0, bg_job 0, boot 0 [2015/09/14 14:58:08 29493] Read 2049488 byte from configuration [2015/09/14 14:58:08 29493] Disk configuration matching with online configuration. [2015/09/14 14:58:08 29493] Should do expand now... [2015/09/14 14:58:08 29493] ===== Partition Entry (MD not used) ===== [2015/09/14 14:58:08 29493] ===== Partition Entry (Used by MD) ===== [2015/09/14 14:58:08 29493] 000 /dev/sdc,W1F2NA5K,8, 32, 2930266584 2930264504 2930264504 MD_FULL 0 [2015/09/14 14:58:08 29493] partitions: 3 property: 4K [2015/09/14 14:58:08 29493] 000 /dev/sdc1, 8, 33, 4194304 MD_FULL md=/dev/md0 [2015/09/14 14:58:08 29493] 001 /dev/sdc2, 8, 34, 524288 MD_FULL md=/dev/md1 [2015/09/14 14:58:08 29493] 002 /dev/sdc3, 8, 35, 2925545912 MD_FULL md=/dev/md2 [2015/09/14 14:58:08 29493] 001 /dev/sdb,S301BHFT,8, 16, 3907018584 3907016483 3907016483 MD_FULL 0 [2015/09/14 14:58:08 29493] partitions: 4 property: 4K [2015/09/14 14:58:08 29493] 000 /dev/sdb1, 8, 17, 4194304 MD_FULL md=/dev/md0 [2015/09/14 14:58:08 29493] 001 /dev/sdb2, 8, 18, 524288 MD_FULL md=/dev/md1 [2015/09/14 14:58:08 29493] 002 /dev/sdb3, 8, 19, 2925545912 MD_FULL md=/dev/md2 [2015/09/14 14:58:08 29493] 003 /dev/sdb4, 8, 20, 976751979 MD_FULL md=/dev/md3 [2015/09/14 14:58:08 29493] 002 /dev/sdd,S301BHV7,8, 48, 3907018584 3907016483 3907016483 MD_FULL 0 [2015/09/14 14:58:08 29493] partitions: 4 property: 4K [2015/09/14 14:58:08 29493] 000 /dev/sdd1, 8, 49, 4194304 MD_FULL md=/dev/md0 [2015/09/14 14:58:08 29493] 001 /dev/sdd2, 8, 50, 524288 MD_FULL md=/dev/md1 [2015/09/14 14:58:08 29493] 002 /dev/sdd3, 8, 51, 2925545912 MD_FULL md=/dev/md2 [2015/09/14 14:58:08 29493] 003 /dev/sdd4, 8, 52, 976751979 MD_FULL md=/dev/md3 [2015/09/14 14:58:08 29493] 003 /dev/sda,Z3039RT9,8, 0, 3907018584 3907016483 3907016483 MD_FULL 0 [2015/09/14 14:58:08 29493] partitions: 4 property: 4K [2015/09/14 14:58:08 29493] 000 /dev/sda1, 8, 1, 4194304 MD_FULL md=/dev/md0 [2015/09/14 14:58:08 29493] 001 /dev/sda2, 8, 2, 524288 MD_FULL md=/dev/md1 [2015/09/14 14:58:08 29493] 002 /dev/sda3, 8, 3, 2925545912 MD_FULL md=/dev/md2 [2015/09/14 14:58:08 29493] 003 /dev/sda4, 8, 4, 976751979 MD_FULL md=/dev/md3 [2015/09/14 14:58:08 29493] Found leftover expansion actions DOING_F_RESIZE , continue... [2015/09/14 14:58:17 29493] LINE 540: exec command: echo "DOING_F_RESIZE" > /.os_V_E_continue [2015/09/14 14:58:18 29493] LINE 4569: exec command: resize2fs -pf /dev/c/c resize2fs 1.41.14 (22-Dec-2010) resize2fs: Memory allocation failed while trying to resize /dev/c/c Please run 'e2fsck -fy /dev/c/c' to fix the filesystem after the aborted resize operation. Filesystem at /dev/c/c is mounted on /c; on-line resizing required old desc_blocks = 581, new_desc_blocks = 639 [2015/09/14 15:11:40 29493] Expand second phase error 10: resize2fs, err=0x100 [2015/09/14 15:11:51 29493] File system expand failed [2015/09/14 15:11:51 29493] LINE 5210: exec command: /usr/sbin/expand_md -a super >> /var/log/frontview/expand_md.log 2>&1 & [2015/09/14 15:11:51 29493] LINE 5213: exec command: /frontview/bin/volumescan & [2015/09/14 15:11:52 29493] STAGE_WIPE: Clean my_pid 29493 [2015/09/14 15:11:52 29810] STAGE_CHECK: saved my_pid 29810 in check mode. [2015/09/14 15:11:52 29810] RAID MODE: 1, sn= File descriptor 3 (/etc/resolv.conf (deleted)) leaked on lvs invocation. Parent PID 29822: sh [2015/09/14 15:11:53 29810] LINE 4928: exec command: lvs > /var/log/frontview/.V_E.snapshotstat [2015/09/14 15:11:53 29810] Current file system status: ext4 [2015/09/14 15:11:53 29810] LINE 6523: exec command: rm -fr /var/log/frontview/.V_E.* [2015/09/14 15:11:53 29810] X_level: 5 [2015/09/14 15:11:53 29810] /usr/sbin/expand_md -a super [2015/09/14 15:11:53 29810] MD degraded 0, bg_job 0, boot 0 [2015/09/14 15:11:53 29810] ++++Write 2049488 byte to configuration++++ [2015/09/14 15:11:53 29810] /var/log/frontview/.known_cfgdir/W1F2NA5K [2015/09/14 15:11:53 29810] gpt sig:0,mbr sig:0,fake type:0 [2015/09/14 15:11:53 29810] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2 [2015/09/14 15:11:53 29810] LINE 9650: exec command: sgdisk -p /dev/sdc | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/W1F2NA5K [2015/09/14 15:11:56 29810] /var/log/frontview/.known_cfgdir/S301BHFT [2015/09/14 15:11:56 29810] gpt sig:0,mbr sig:0,fake type:0 [2015/09/14 15:11:56 29810] get disk /dev/sdb format is (GPT=2,MBR=1,MX=3,MISC=-1): 2 [2015/09/14 15:11:56 29810] LINE 9650: exec command: sgdisk -p /dev/sdb | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/S301BHFT [2015/09/14 15:11:59 29810] /var/log/frontview/.known_cfgdir/S301BHV7 [2015/09/14 15:11:59 29810] gpt sig:0,mbr sig:0,fake type:0 [2015/09/14 15:11:59 29810] get disk /dev/sdd format is (GPT=2,MBR=1,MX=3,MISC=-1): 2 [2015/09/14 15:11:59 29810] LINE 9650: exec command: sgdisk -p /dev/sdd | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/S301BHV7 File descriptor 3 (/etc/resolv.conf (deleted)) leaked on vgscan invocation. Parent PID 29860: sh File descriptor 3 (/etc/resolv.conf (deleted)) leaked on lvdisplay invocation. Parent PID 29812: sh File descriptor 3 (/etc/resolv.conf (deleted)) leaked on pvdisplay invocation. Parent PID 29812: sh File descriptor 3 (/etc/resolv.conf (deleted)) leaked on pvdisplay invocation. Parent PID 29812: sh [2015/09/14 15:12:00 29810] /var/log/frontview/.known_cfgdir/Z3039RT9 [2015/09/14 15:12:00 29810] gpt sig:0,mbr sig:0,fake type:0 [2015/09/14 15:12:00 29810] get disk /dev/sda format is (GPT=2,MBR=1,MX=3,MISC=-1): 2 [2015/09/14 15:12:00 29810] LINE 9650: exec command: sgdisk -p /dev/sda | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z3039RT9 [2015/09/14 15:12:02 29810] LINE 5297: exec command: ps -ef | grep -v expand_md > /var/log/frontview/.V_E.snapshotstat [2015/09/14 15:12:02 29810] gpt sig:0,mbr sig:0,fake type:0 [2015/09/14 15:12:02 29810] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2 [2015/09/14 15:12:02 29810] /dev/sdc used/total/partitioned = 2930264504/2930266584/2930264504, 60000000 [2015/09/14 15:12:02 29810] gpt sig:0,mbr sig:0,fake type:0 [2015/09/14 15:12:02 29810] get disk /dev/sdb format is (GPT=2,MBR=1,MX=3,MISC=-1): 2 [2015/09/14 15:12:02 29810] /dev/sdb used/total/partitioned = 3907016483/3907018584/3907016483, 60000000 [2015/09/14 15:12:02 29810] gpt sig:0,mbr sig:0,fake type:0 [2015/09/14 15:12:02 29810] get disk /dev/sdd format is (GPT=2,MBR=1,MX=3,MISC=-1): 2 [2015/09/14 15:12:02 29810] /dev/sdd used/total/partitioned = 3907016483/3907018584/3907016483, 60000000 [2015/09/14 15:12:02 29810] gpt sig:0,mbr sig:0,fake type:0 [2015/09/14 15:12:02 29810] get disk /dev/sda format is (GPT=2,MBR=1,MX=3,MISC=-1): 2 [2015/09/14 15:12:02 29810] /dev/sda used/total/partitioned = 3907016483/3907018584/3907016483, 60000000 [2015/09/14 15:12:02 29810] used_disk_pt_count:4,start:4 xraid level is 5 [2015/09/14 15:12:02 29810] Not enough disk for a new array, drives with free space: 0, X_level:5 [2015/09/14 15:12:03 29810] STAGE_WIPE: Clean my_pid 29810
- StephenBSep 15, 2015Guru - Experienced User
Expansion is also failing due to memory allocation
I don't own a v2 - but if you know of a place where the amount of memory is displayed, you should check to make sure that it is seeing 256MB.
I also suggest a memory test from the boot menu (http://www.readynas.com/download/documentation/HM/ReadyNAS_Duov2_NV+v2_HW_en_19-Sept-11.pdf ). Unfortunately Netgear doesn't disclose how to tell if the test passed/failed. But you could take a short video, and post the link here, they should be able to interpret the results here.
Are you the original purchaser? If so, when did you purchase? The warrany is 3 years. If you are still covered I think you have have enough evidence of a hardware fault that they should diagnose it w/o charge
- RaaahbinSep 15, 2015Aspirant
This is the entirety of mem_info.log:
MemTotal: 246820 kB MemFree: 24704 kB Buffers: 5540 kB Cached: 60848 kB SwapCached: 18348 kB Active: 66812 kB Inactive: 96552 kB Active(anon): 41012 kB Inactive(anon): 56412 kB Active(file): 25800 kB Inactive(file): 40140 kB Unevictable: 376 kB Mlocked: 0 kB SwapTotal: 524268 kB SwapFree: 495600 kB Dirty: 296 kB Writeback: 0 kB AnonPages: 80176 kB Mapped: 13952 kB Slab: 20804 kB SReclaimable: 4624 kB SUnreclaim: 16180 kB PageTables: 2172 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 647676 kB Committed_AS: 726704 kB VmallocTotal: 385024 kB VmallocUsed: 940 kB VmallocChunk: 382812 kB
And this is memory.log:
SZ: 256 AT: SDRAM
Looks to me like it can definitely see 256MB. But now I'm going to have a go at that memory test, so at least I have the results when talking to support.
I just looked up my receipt for purchasing the unit: looks like the timing is good! 30 Sep 2012. So I'd better get on with diagnosing any hardware failure.
I'd open the support ticket now, that will document that the problem started under warranty.
