ravi926
Sep 12, 2022Aspirant
Replacement disk RR4360S
There is a disk which is going to fail (Detected increasing reallocated sector count), Do need to shutdown the system RR4360S and swap the drive or are the drives hot swappable ?
Sep 12, 2022Guru - Experienced User
The drives are hot swappable.
- ravi926Sep 16, 2022Aspirant
Thanks, just curious to know during what situation we need to shutdown the array and replace, have read from one of the forums https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Dead-volume-after-disc-replacement/td-p/1249309
- StephenBSep 16, 2022Guru - Experienced User
Normally you don't (fwiw I never have).
What RAID mode are you using for the volume the failing disk is in?
- SandsharkSep 16, 2022Sensei
The post you referenced has nothing to do with whether or not the NAS was shut down. No matter how you do it (power on or off), a replacement drive has to complete RAID sync. Depending on the RAID type, other failures during that process can kill the volume.
