kevinffff
Jun 28, 2021Aspirant
Replacement fan - RN516
My fan has started to become noisy, regardless of speed setting, where can I can a replacement from please?
Sandshark
Jul 05, 2021Sensei
Unfortunately, I've not seen anyone chime in with a specific model as a replacement. Once you get one installed, then you'll need to see if it stalls out or needs a spe4ed boost to cool well enough. If it does, then those can be adjusted via SSH.
kevinffff
Jul 06, 2021Aspirant
I have ordered this, will see how it goes:
CYRMZAY Compatible for NMB-MAT 4710KL-04W-B56 12cm 12025 120mm DC 12V 0.72A 4-wire PWM case cooling fan
- SkepherAug 18, 2021Aspirant
How did the fan replacement go?
my fan is starting to make noise as well.
- kevinffffAug 19, 2021Aspirant
I waited weeks for the fan to arrive from China, by the time it arrived I was busy and the existing unit had stopped making any noise, so I humbly admit I've let sleeping dogs lie, for the moment.
