soupboy
Aug 06, 2018Tutor
Replacing Drive after Failure - OFFLINE/UNKNOWN state
Screenshots below: We have 8 drives in a RAID 10 structure.
The drive in channel 6 failed and was in OFFLINE state. We then removed it, and replaced it with a new 4TB drive.
Ideall...
Retired_Member
Aug 06, 2018Hello soupboy
Can you please update latest ReadyOS 6.9.3?if updating firmware is unable to fix the raid recovery issue,please email the system log to nsbu_logs@netgear.com,thanks!
soupboy
Aug 06, 2018Tutor
I'm not sure if 6.4.2 is causing an issue in Raid recovery, do you think this is the case?
Because straight away updating the firmware may not be the solution.
Also, say I do update the NAS, do you think that the disk in channel 6 can remain in the machine during update, or should I remove it, update and then re-insert?
Thanks Deniro, for your reply.
