Andrea_N
Sep 23, 2023Aspirant
reset rndp6000
Hi all, I have an old NAS ReadyNAS Pro Business Edition RNDP 6000 (but with label 6310) to repair. I had a factory reset and when I start I only find the shared folder screen (empty) and the passwo...
Andrea_N
Hi, thanks for reply.
1) on the display I only see IP and free space
2) responds page PR_CONNECT_RESET_ERROR
3) the same
I attach what I see
thanks you
Sep 23, 2023Guru - Experienced User
Andrea_N wrote:1) on the display I only see IP and free space
What does RAIDar show you?
- Andrea_NSep 23, 2023Aspirant
I did a good thing.. I threw it away and bought another one.
There will certainly be smb problems and old things that are no longer supported today.
I don't even know how old it is, but it definitely won't run w11 anymore
So, I don't waste time.
Thank you - Andrea_NSep 24, 2023Aspirant
Anyway, to answer your question:
I launched RAIDAR on the PC and I see the NAS with firmware 4.2.31
and clicking on "administrator page" the browser responds with an error:
"SSL_ERROR_UNSUPPORTED_VERSION" and
"This website does not support the TLS 1.2 protocol"Please tell me if I'm right to throw him away or if there is a way to communicate with him nowadays with the new protocols
thank you
- StephenBSep 24, 2023Guru - Experienced User
No need to throw it away. There are two ways to add TLS 1.2 to your NAS
- convert the NAS to run OS-6 firmware or
- install an add-in to 4.2.31
The first option is best (it also adds SMB 3.x), but it does require increasing the RAM to at least 2 GB - which is inexpensive and easy to do.
Either way, you can get temporary access either by
- Using internet explorer (if still installed on the PC)
- Using Edge in IE mode
- Using Firefox, and setting security.tls.version.min to 1 (browse to about:config and search for the setting).
The add-on link is there:
After you install that, we can follow up on converting your NAS to OS-6 if you are interested.
In fact I tried to connect with an old laptop with XP to the admin page and it works.
I see the panel settings.
Now I will follow your advice.
Thank you
