rickwookie
Aug 25, 2013Aspirant
Restore config after reset does not re-create home shares
Hi I've got myself some new 2TB WD Red drives for my NV (RAIDiator 4.1.12), so I decided to do a full backup of the config and volume c, and factory reset to get 16k sectors (my original install wa...
rickwookie
Well, I never realised I could connect to smb://admin@MyNASHost/c until you suggested that! I could have not deleted the files in .bittorrent from my backup as I did a couple of hours ago thinking there was no way to restore them.
I've just created a folder for each user missing a home share in c/home and sure enough the shares now show as a source/destination in 'Add a New Backup Job', meaning I can create a job for each share to restore from the NFS backup and retain the correct permissions (hopefully).
Your suggestion would probably be quicker, particularly for large number of user home shares, but is the permissions the only thing that gets lost doing a cifs drag'n'drop compared to the restore via NFS backup job? Where can I get this add-on that fixes permissions btw? I can't see it here: http://www.readynas.com/?page_id=617 or here: http://www.readynas.com/?cat=36
