nbarrettn
May 30, 2018Aspirant
Retrospective Encryption RN314
Hi All
When creating a partition you have the option to encrypt it. Is it possible to enable that after the partition is created or is the the only option to delete and recreate it?
Usi...
- May 30, 2018
You can't retrospectively encrypt a volume - so you'd need to delete it and then recreate it. Uninstall your apps first (as they are stored on the data volume).
May 30, 2018Guru - Experienced User
