ovrdrvn
Mar 04, 2016Aspirant
Reviewing Time Machine Backups
After mounting the ReadyNAS share, does anyone know how I can review in detail what is in that image? I can't seem to browse via a terminal session (root acccess?) and mounting it etc doens't reveal ...
ovrdrvn
Thank you but I"m aware how to do that. I need to access what is on this share not increase capacity (in fact, I have none less to increase anyway) And this share is not browseable in the Finder nor have I ever seen this to be the case with a ReadyNAS. The bundle that you can get to doens't give you access to the files. THere is some permission issue or such.
JennC
Mar 04, 2016NETGEAR Employee Retired
Hello ovrdrvn,
It only saves the disks image format of called sparsebundle that needs TimeMachine of your Mac to open.
- mdgm-ntgrMar 06, 2016NETGEAR Employee Retired
The "Enter Time Machine" option in the Menubar under Time Machine is the best way to look for contents of a Time Machine backup.
