Angeld
Dec 17, 2015Aspirant
RN 104 LED Says PAGE_ADDRESS+8
Hi I have a RN104 and decided to upgrade to firmware 6.4.1. and after rebooting my led screen says PAGE_ADRESS+8 its been that way for around 4 hours. I know the release notes say it has to do a sca...
- Dec 19, 2015
Hello Charles
Thanks for the info. I ended up trying to talk to tech support but they quickly had to escalate the case and looks like they want me to pay for help with it even though its still under warranty. I decided to just turn it unplug it and try to do a USB install of the os. That went quickly and it rebooted fine. I was able to login in and access the admin panel and noticed it started to sync the volume data. Well after about 30 min of that it gave the same error. So I just unplugged it and started plugged it back in it booted back up fine again and went back to syncing the volume data.
I though for a min and since its so underpowered system I went in and turned off all the apps I had incuding Virus-Scan and all of the services I dont really need like FTP and itunes. Its been running for 12 hours now no problem still syncing the data though. I have been able to look around the shares and copies a file off and seems to work. Both SMB and AFP are working for me. But I don't want to mess around too much till its done.
I also don't seem to have much luck with the ReadyNAS recently. Bought a RN315 to upgrade from my RN104. Got it suck a scratch drive in like what was recommended. Updated to 6.4.1 was just messing around with settings and loading apps. Rebooted the NAS and itgave me a lcd message of "mount_boot_root +1e9" and I as unable to see the device on any of my comps. Was unable to get in to the boot menu or even do a usb os install either. Tried diffrent drives also and nothing so its getting sent back. Not sure what I want to end up doing now.
Anyways thanks again for the info I will let you know how my RN104 is working after its done syncing the data in about 70 hours or so the admin page says it will take.
Angeld
Dec 18, 2015Aspirant
No luck its now been on for about 16 hours and still says PAGE_ADRESS+8.
- AngeldDec 18, 2015Aspirant
Getting really worried now at 28+ hours. Well I have a new 315 on its way to me it will be here tomorrow. Any ideas if will be able to upgrade it like you said and not loose my data or am I gonna be sol?
- Magic_CrazyDec 19, 2015Aspirant
Hello,
I have the exact same problem. I upgraded my RN104 from 6.2.5 to 6.4.1, since I can see the same error message on the LED Screen.
When I boot it, I have access to te administration page. After some minutes, The error message appears, and I have to unplug it from AC in order to reboot it (even push the power button for long seconds doesn't work).
I think this might be a problem with Samba sharing, as the error appears earlier if I try to access the files from my Windows PC. I didn't try other services for now.
As I'm writing, I booted the NAS without network plugged in, and I don't see the error appearing. I'll investigate further. In the meantime, if you need anything from me, I'll do my best.
Charles.- AngeldDec 19, 2015Aspirant
Hello Charles
