6ril
Dec 20, 2014Aspirant
RN 104 poor performance -> unusable
Hi,
I have a RN 104 with 3 2TB disks in RAID5.
The performance I'm talking about is simply FOLDER ACCESS!!
some folders can be accessed normaly, and others are just unbearable slow, like 7 minutes before I can see the content! and then after seeing the content, if I for exemple install a very small soft from there, it takes another 10 minutes, if it ever launch it.
I can't stand it any more, please help me :(
- vandermerweMasterSo the problem with failure to shut down is still there?
Have you upgraded to 6.2.1? Does the nas reboot properly?
If you shutdown using the power button, does it also hang?
You should try an OS reinstall using the boot menu:
http://kb.netgear.com/app/answers/detai ... -or-314%3F
Do you have a backup of your data?
It is the weekend before Christmas,I think it is a bit much to expect Netgear to be patrolling the forums right now. - bmantoothAspirantI am having similar problems with a ReadyNAS 104. running 6.2.2 frimware.
From windows 7, and from windows 8.1 machines, over wired or wireless connections (from the computer) it can take 15-30 seconds (or way longer) to display the contents of a folder in windows explorer. Sometimes there is a full time-out with no response. In this case I have mapped the NAS to a drive. I have also tried this using network paths such as \\192.168.1.my_IP\my_folder\ with the same kind of response times.
This makes the NAS almost unusable for my intended purposes. After reading this thread, I tried disabling Antivirus and that seems to have fixed the problem. So, now a security question. I have all of my computers running antivirus software - what is the risk of running the NAS without its AntiVirus? Is computer antiVirus good enough? If Antivirus is that much of a burden on the NAS 100 series, why is it there - I agree this makes it unusable?
Services running on the NAS: SMB, AFP, HTTPS, FTP, AntiVirus
Network: LinkSys E3400 GBit wired and N wireless network.
Disk configuration: 3 x WD Red 4TB, in RAID 5, using the "X-RAID" configuration
I have a Gigabit 8 port switch hooked up to the LinkSys to connect printers, computers and the ReadyNAS.
I have tried the ReadyNAS hooked up with one or two hard-wire connections - no effect on directory display speed.
Using NAS performance tester 1.7 I have the following transfer speeds over a wireless connection -
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 400MB file write on Z: 5 times...
Iteration 1: 9.00 MB/sec
Iteration 2: 5.57 MB/sec
Iteration 3: 5.22 MB/sec
Iteration 4: 5.26 MB/sec
Iteration 5: 7.25 MB/sec
Average (W): 6.46 MB/sec
Running a 400MB file read on Z: 5 times...
Iteration 1: 9.14 MB/sec
Iteration 2: 9.69 MB/sec
Iteration 3: 9.38 MB/sec
Iteration 4: 9.25 MB/sec
Iteration 5: 10.28 MB/sec
Average (R): 9.55 MB/sec
