lundmilo
Jan 23, 2016Luminary
RN 204 snapshot
I am having trouble understanding how to use snapshots on my ReadyNAS 204 (firmware 6.4.1). I used to have a ReadyNAS Duo V1 that started to drop of my network, so I decided to buy a 204. ...
- Jan 30, 2016
I have just about 1 TB of data on my 2 TB RAID 1 array.
It looks like It is working after I copied my documents (Word/Excel/Vegas Pro etc.) to the documents share and enabled Snapshot on this share.
I guess the ReadyNAS is confused that there is a share with the same name at the volume.
The files that are left in the "Data" share are files that is not changed very often, and since I do backup twice a week, the snapshots are not needed on this share.
Thanks for all the replies.
lundmilo
The NAS is running 24/7, so i assume that the snapshot should be created if i change or delete a file.
I have mainly been adding lines to spreadsheets and adding PDF files to the folder, but I have not deleted any files yet.
/Michael
Jan 23, 2016Guru - Experienced User
It should be creating a daily snapshot even if the share hasn't changed at all.
If you purchased within the past 90 days you might want to use your telephone support.
- lundmiloJan 23, 2016Luminary
Hello again,
It seems like a snapshot has been created this midnight, although it is another shared folder than it should be. I want the "Data" folder to do snapshots, but the "Documents" folder now has a snapshot but nothing seems to be in that folder.
I just tried making a manual shapshot og my "Data" folder but the ReadyNAS reported:
Snapshot failed
28003020000
Error in creating a new snapshot
/Michael
- mdgm-ntgrJan 24, 2016NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
- StephenBJan 24, 2016Guru - Experienced User
Data is usually the volume name, not a share name. Does "Data" appear on your share list in the web ui? If so, what is your volume name (on the volume tab)?
- lundmiloJan 24, 2016Luminary
The volume is named "data" and on the volume i have a share called "Data"
/Michael
