530_R4i8R's avatar
Jan 06, 2016
RN102 After duplicated HDD to larger capacity, total capacity not correctly reported
My intended goal was to upgrade the drives to 1TB and mirror the data on the first drive to the second. So I was feeling pretty lazy and I went about attempting to upgrade my RN102 v6.4.1 disks the s...
  • 530_R4i8R's avatar
    530_R4i8R
    Jan 06, 2016
    *UPDATE*
    mdgm thanks for the advice, I'll remember it should/when I ever have to upgrade to larger HDD's in the future.
    Turns out I monkeyed my way into making my sloppy HDD upgrade work. I previously rebooted the NAS several times when I first realized the total drive capacity was not correct hoping it would resync and correctly report the volume capacity, it didn't work which is why I originally started this thread.
    After I posted this thread I shut down the NAS and removed the drives to label them, when I reseated the drives and rebooted the drive health initally showed up as degraded as it went through a resync process and finally showed up as healthy and redundant, it is still in the resync process at 45% complete but it appears as though it has corrected the disk capacity issue on it own
ProSupport for Business
