Persilja
Jul 30, 2016Aspirant
RN102 disappears from network
I got it this spring, but since I ran into some issues with the setup at the time and didn't have time to troubleshoot it then, I haven't made a concerted effort to setting it up until this last week...
bedlam1
Jul 30, 2016Prodigy
I think if I was exeperiencing your scenario, particularly as you had initial setup problems and have no problem with losing all the data on your disks, I would perform a factory default reset and start again, allowing the unit to seek updates itself, as you cannot install 6.5 directly from some earlier versions
See here how to access the boot menu
BTW this will change the admin password to "password", also you have to press the blue button twice to shut down gracefully
