WelshCJ
Feb 10, 2015Aspirant
RN102: No Frontview access after Uninstall of Owncloud
Evening All, I just bought the RN102, and everything was going well with it, I decided to install a few of the applications which included OwnCloud. After a bit of a play I decided it was not wh...
Burts
Feb 22, 2015Aspirant
Hi
I've uninstalled owncloud yesterday (RN102 with 6.2.2), and no frontview from that moment.
Apache2 doesn't want to start :
I'm guessing it's the same issue .. could you post the workaround you used ?
XXXXX:/etc/frontview# systemctl status apache2
apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled)
Active: inactive (dead) (Result: exit-code) since Sun, 22 Feb 2015 12:25:31 +0100; 8min ago
Process: 4614 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exited, status=1/FAILURE)
Process: 4608 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS)
CGroup: name=systemd:/system/apache2.service
