WelshCJ
Feb 10, 2015Aspirant
RN102: No Frontview access after Uninstall of Owncloud
Evening All, I just bought the RN102, and everything was going well with it, I decided to install a few of the applications which included OwnCloud. After a bit of a play I decided it was not wh...
EskenderNG
Apr 11, 2015NETGEAR Employee Retired
Hello,
Unfortunately the update itself will not restore the web interface access. It will only, among other things, prevent you from losing access again.
To solve you current issue you can also contact Netgear Support. They will take care of you.
Bye,
Eskender
Bye,
Eskender
