adisinha
Jan 06, 2017Tutor
RN102 power led keeps blinking after firmware update
Hi, Tried updating firmware to the latest version and now the NAS has gone into a Coma. POWER LED is blinking since the firmware update started approx 2 hours ago. All other LEDs are on and solid...
Jan 06, 2017Guru - Experienced User
What firmware were you running before? Did you upgrade to 6.6.1 or something else?
adisinha
Jan 07, 2017Tutor
Sorry didnt pay attention before upgrading, assuming it is upgrading to the latest version. It had been a while since i last updated though.
Had this same issues a couple of years ago and had to have the NAS chassis replaced as the system would not recover even after doing a factory reset.
- adisinhaJan 07, 2017Tutor
Upgraded to v6.6.0
A couple of reboots has resolved the issue for now. Thanks ! I can now login to the admin page and access the shares.
Will now setup backups to a usb hdd.
- FramerVJan 09, 2017NETGEAR Employee Retired
Hi adisinha,
Thank you for the update.
After your back-up, I would be suggesting that you do a firmware upgrade. There are bug fixes on it and I think it will be improving the ReadyNAS performance.
ReadyNAS OS 6 Software Version 6.6.1
- JennCJan 12, 2017NETGEAR Employee Retired
Hello adisinha,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
