AdrSny
Sep 10, 2013Aspirant
RN102 setup help
Hi all I'm a NAS newbie. Bought the RN102 and a Seagate 3T drive 2 days ago. Installed the drive, power on, and 2 day later still the flashing power light. I tried the reset button procesur...
vandermerwe
Sep 10, 2013Master
Can you access the user interface using readycloud or raidar?
Is the disk on the HCL?
Did you test the disk using seagate tools on your PC?
If you can't access GUI and the disk is ok, factory default the unit using the boot menu.
http://kb.netgear.com/app/answers/detai ... -or-312%3F
To force a power down, pull the power.
After factory default, try again and post results.
