AdrSny
Sep 10, 2013Aspirant
RN102 setup help
Hi all I'm a NAS newbie. Bought the RN102 and a Seagate 3T drive 2 days ago. Installed the drive, power on, and 2 day later still the flashing power light. I tried the reset button procesur...
vandermerwe
Sep 10, 2013Master
Have you tried a factory default?
I'd suggest if you have checked the disk and its ok, and the factory default doesn't sort it out, that you contact Netgear support. If you bought the 102 new you have 90 day telephone support and of course the warranty.
There is also online support which is very good.
How is your readynas connected to your network?
