piechu
Nov 15, 2014Aspirant
RN102 write speed is extremely slow - what's the problem?
Hello. Yesterday I bought a ReadyNAS 102. Before buying I read a lot of tests and I was aware of its advantages and disadvantages and in particular the slow speed writing. However, after connecting a...
Nov 15, 2014Guru - Experienced User
Your router will limit your speed to ~10 MB/s since it is only fast ethernet. So after you solve the main speed issue, you might want to add a gigabit switch or perhaps upgrade the router to a gigabit one.
Did you install readynas remote on the PCs? If so, you might try disabling the leaf VPN adapter.
