piechu
Nov 15, 2014Aspirant
RN102 write speed is extremely slow - what's the problem?
Hello. Yesterday I bought a ReadyNAS 102. Before buying I read a lot of tests and I was aware of its advantages and disadvantages and in particular the slow speed writing. However, after connecting a...
xeltros
Nov 17, 2014Apprentice
Just a little thing here, since you have a new unit, I would advise to do a factory reset if you haven't done it after upgrading. There were some changes to the filesystem with the 6.1.5 that need to be applied via a factory reset. They shouldn't do much difference but it's always good to start clean.
As for the speed, did you copy large file or only word documents ? Is the rebuild process (if two disks) finished ? Is the antivirus turned off ?
