piechu
Nov 15, 2014Aspirant
RN102 write speed is extremely slow - what's the problem?
Hello. Yesterday I bought a ReadyNAS 102. Before buying I read a lot of tests and I was aware of its advantages and disadvantages and in particular the slow speed writing. However, after connecting a...
mdgm-ntgr
Dec 24, 2014NETGEAR Employee Retired
xeltros wrote:
The reset was intended after the 6.1.5 update only. The reason is that the filesystem structure was changed. That's the only update that requires it. AFAIK 6.1.9 to 6.2.0 will not require a reset (beta doesn't).
You don't need to do a factory reset (wipes all data, settings, everything) after any firmware update. Though there can be benefits such as the filesystem improvements in 6.1.5 (and later), getting a clean install etc.
